fat wheel psi
Ahmed55555
28
Hi, I have a 20x4 fatwheel ebike which has a 500w geared hub motor, whats the best psi for a comfortable ride with stability and speed? I ride on London roads. I'm 100kg
2,675
According to https://bicycleer.com/fat-bike-tire-pressure/ around 20-25 PSI. I guess a fat tyre like that will always be reasonably cushioned against all but the worst potholes; I'd go for the top of the range specified on the tyre.
... but that is based on guesswork and 2nd hand information, I've never ridden a fatwheel bike.
georgehenry
1,435
1,259
Surrey
Trail and error may be the best. Use a tyre pressure gauge. You should be able to feel how compromised you handling is, especially cornering on the road, and get a good understand of the lowest pressure you can run on the road without compromising your cornering.
With those types of bike you may be able to work out a range of pressures for different conditions, eg sand, mud, rock.
I have a 2.35 gravity mud tyre on the rear and run it around 30 psi as a good road and off road compromise pressure.
Basically I pump it up to 30psi, and am in the habit of a quick check, squeezing each tyre before a ride. The back will slowly lose pressure over time, which makes it better off road and not so good on road, and when I can tell it has lost too much pressure, or feel the handling is too compromised for the road, pump it up again.
Keeps thing simple.
3,003
Related subject - this turned out to be a decent impulse purchase at a very low price:
It's still working, 5 minutes later.
Reactions: richtea99
RoadieRoger
720
196
I have been riding my` Lanarkshire E Bikes `Fat Tyre for 3 years and have an original Kenda Krusade 20x4in. Tractor pattern on the rear and a Chaoyang Sand /Road tyre diamond pattern on the front . The maximum recommended psi for the Kenda is 30 , so I inflate to just under , approx. 29 psi . The Chaoyang has a recommended maximum pressure of 20 psi , so I run it at just below 25 psi . The ride is firm and not helped by the soft/poorly damped front fork .
These 20x4 in. tyres can be expensive , I bought 2 from RIDEWILL in Italy for £20 each plus postage but I don`t think they supply to the UK now because of Brexit . I bought another 2 Chaoyangs from a place in London that had a special offer of two for the price of one , if I remember correctly .
Simonwwfc
219
36
I have also just purchased a fat tyre ebike I had my rear on 27psi and front on 25psi . The side wall of the tyre says 30psi I’ve now reduced my pressure to 20psi much nicer ride also on 20x4” tyres
