Over the past few weeks I noticed when pedalling moderate to hard that occasionally the sprocket would jump, I thought it was the derailer not aligned properly and the chain jumping gears, but today I discovered what the real problem was - cycling home in near freezing temperatures (it's now below 0 outside) the freewheel in the sprocket stopped working properly, every so often it would just spin when I tried to pedal, resulting in the chain coming off and getting completely stuck between the sprocket & frame. I had to 'hobble' the last mile back, throttle on the flat & walking up the hills
Is the freewheel in the sprocket fixable or should I replace it? if I can, because of the power cable going in through the middle of it all. I have wanted a lower low gear for a while now to help with the really steep hills when I'm carrying extra kilos in the panniers.
