Hi Just because they show voltage dont mean to say they are fully charged this is where you need to charge each cell pack individual you buy one off the chargers i listed the when the charge light changes to green then they are charged
Frank
Ah D8ve that explains my confusion!Could the Bristol thing be me D8ve in Bristol but D8veh in Telford
There's very little difference in charge between 3.55v and 3.61v. Even with a single cell charger, that cell would climb very quickly to 3.61v, so I don't believe it's a problem of balance, but instead I think there's something wrong with that cell. Ideally you need to follow the balance wire to find out which one it is. Maybe you can see something visually, like squished or leaking, so do that first. Another thing to do is charge up the pack, measure the cell voltages, leave it for a day and measure again to see if it's self-discharging, which it probably is if it's faulty.
Buy few spare cells and solder them to your pack.
Removing a string of cell will make your bms incompatible with your pack
