Fitting a PAS Sensor to the crank - how ?
Tubamanandy
267
38
Anyone know how easy/hard it is to fit a PAS sensor to the crank ?
I've got one to fit but unsure if there are any special things you need to watch for or even how to do it to be honest.
Any help appreciated
8,233
Which type of bottom bracket is fitted to your bike ? Sq taper , octalink etc,etc and which type of pas sensor are you fitting.
8,233
You need to take a close up pic of the crank/ bottom bracket and show us , take one from the LHS.
8,233
Can't really tell from that pic and angle, might have to remove crank arm and retake pic.
8,233
This pas uses a stick on type of adjustable sensor that is also cable tied.
The magnet ring centre is drill out and fitted in place of the small drive, granny ring.
This pas sensor is the type that is fitted to a stainless bracket that fits over /behind the bottom bracket shell and the magnet ring is as the other one above.
Alan Quay
2,351
1,076
Devon
From the pic I'd guess you have a square taper. Remove the left crank arm (non drive side), put sensor behind BB retaining ring, magnet ring on crank shaft, refit crank arm. Simples.
8,233
