Freewheel to cassette conversion?
cwah
3,048
179
www.whatonlondon.co.uk
Hello,
I've had experienced such a pain to remove freewheel once they are on the bike for a little while that I'd like to convert all my motors to cassette...
Unfortunately, it doesn't seem to have any simple solution for that...
Would... to some extend, having a single speed conversion an alternative to that?
http://www.amazon.co.uk/A2Z-Mountain-Single-Speed-Conversion/dp/B0071A3W7K/ref=sr_1_fkmr1_1?ie=UTF8&qid=1430874406&sr=8-1-fkmr1&keywords=single+speed+conversion+kit+freewheel
Something like this would make changing the gear easy? Or is it a wrong solution?
trex
7,703
2,671
wrong solution.
You need an adjustable wrench with a long handle. I use one with 250mm handle, not specially long but long enough, and step on it with my foot.
mfj197
553
160
Guildford
As far as I know it's not possible to convert a motor from freewheel to cassette - it's new motor time. The single speed conversion you link to is for a freehub anyway, i.e. it fits on to the same splines as a cassette and isn't a freewheel which is what you would need.
C
Cyclezee
Hi cwah,
It's not that difficult, all you need is a removal tool and spanner with long handle. See this video
30,790
The reason conversion isn't usually possible is that most hub motors uses 12 mm spindles to allow for the hole through the centre for the electrical cable going in.
Cassettes are only suited to the normal 10 mm bike spindles and won't fit over 12 mm ones.
What about cassette motors? They have a 12mm axle with the wire up the middle.
30,790
I take it that it's a different cassette for those though, I was thinking of the usual Shimano etc which are for 10 mm spindle mounting.
cwah
3,048
179
I haven't found any decent tool to remove it easily. I'm not a strong guy either and every time it was such a pain I gave up.
I can't change all my motors to cassette it would be too expensive!
john h
510
147
murthly castle estate
cawh go on to youtube and type in RJ THE BIKE GUY. shows how to take them off, even without the proper tools how to strip + rebuild them +brakes ,wheels ,converting from 7 to 10 speed even how to expand the rear stays
mfj197
553
160
Guildford
If it's a problem just take it to a bike shop to undo. It can't surely be a very common task for you to have to do? If you're mostly using high power hub motors the sprocket's not doing much at all, so ought to last many thousands of miles.
Michael
30,790
If right handed, use your left arm over the wheel to pin it down onto the floor and hold a ring spanner end in onto the removal tool with that hand. Then with a hammer in your right hand strike the outer end of the ring spanner sharply to break the initial bond of the thread. The tool will then spin off the freewheel easily.
flash
195
84
69
CW12 Congleton
I clamp the tool in the vice on my work bench. I leave the wheel nut or skewer keeping a slight tension on the tool. I then grasp the rim and jerk it anti clockwise to break the the initial tightness. Very rarely fails.
But all cassettes go on the same standard spline.
cwah
3,048
179
Could you advise on the right tool to use? My spanner usually flip over it and anyway I never have enough strength and leverage to move it.
I was considering buying a leverage bar but it adds more clutter to my home and I don't know to what extent it's going to be useful
C
Cyclezee
If you are only ever wanting to do this once you could take the bike to an LBS and get them to undo it for a couple of quid....or in London 20 quid:eek:
Kenny
383
111
West of Scotland
I used to use a 12" shifter but sometimes it would slip off the hex with a really tight Freewheel.
I found an old 9/16 BSW ring spanner about 15 inches long, which was a perfect fit on the freewheel tool. No more slip, and haven't had a problem loosening them since.
jhruk
318
68
For this sort of job I use a length of old scaffolding tube as an extension bar - it fits over the end of most spanners. If you visit a scaffolders yard they will probably sell you a length for around a fiver. Over the years it's been one of the most useful 'tools' I have.
30,790
You can tell I've mostly been a hub gear man! :)
Left the cassettes to the lycras, only freewheels on the rear hub motors I've had, and took it on good faith when told the reason for that (spindle size). It seems was wrongly informed.
cwah
3,048
179
