Hi all
I'm selling my Club Rost XC4 BBS02 based ebike.
The bike specs are as follows:-
Club Roost XC4 frame, Fox rear shock, 100mm rear travel.
Rock Shox Reba Race 100mm forks - serviced by me with new seals in the summer.
SLX shadow+ clutched rear mech.
11-36t 10 speed cassette.
Deore M595 disc brakes - 180mm front / 160mm rear.
BBS02 48v/500w crank drive kit.
15.2ah of 44.4v lipo (675wh) - into two packs - made up of 2x10000mah 6s Multistars in the frame box and an extra 2x5200mah Multistars in a saddle bag - wired for parallel use or singly (can use either pack on it's own or both together).
Less than 10 cycles on the packs and 200 miles on drivetrain.
Frame size is medium - for up to 6ft rider (I'm 5ft11in).
Crank drive kit has been customised to allow 100% throttle in all assist levels.
Frame has had extra welding around the pivot points (a known weak point on these frames) - this was done by a local engineering shop to a high standard - they sepcialise in automotive alloy welding.
Carbon reinforced battery frame box.
42t chainwheel - improves climbing ability and chaninline.
Chain keeper fitted.
Voltmeter mounted below display.
Includes usb programming cable.
The bike rides like new with very low mileage on all components.
Looking for £2000 inc battery packs, to pick up from Blackpool but can travel around 50 miles to meet up somewhere if required.
More pics below, ask if you want any more and I'll happily get them:-
