I plan on trying to fit a 41tooth chainring on my Lafree instead of the 37t that's currently installed, has anyone ever tried this and will it fit?
Hi hech,Evening Tarik and welcome to da forum. The venerable Flecc, our esteemed leader is the world authority on the Giant Lafree and will know all answers to everything you might wish to know.
Just as long as your bcd measurements are agreeable, sounds like a thoroughly good idea to me.![]()
The 41t chainring from the later panasonic model should fit the socket yes.Hi Tarik,
As the LaFree has a one piece chainwheel that fits on a splined shaft, I doubt if there is an alternative to the standard without some engineering unless the chainwheel from the later Panasonic motor as used Kalkhoff etc. is compatible?
Why would you want to do this?
To alter the gearing, it is relatively simple to change to different size drive sprocket.
The following will take you to Flecc's LaFree website lafree
Which Panasonic unit is the dongle for? Is it the older version used on the Lafree, the standard 24 Volt version used on the Kalkhoffs from about 2007 onwards, the S Class 24 Volt version or the latest 36 Volt Version? Just curious.May I add, we will soon be stocking a dongle to adjust the bikes cut off speed a bit like the Bosch dongle. This is in the making and should be expected for the Panasonic unit soon.
Hi Tillson,Which Panasonic unit is the dongle for? Is it the older version used on the Lafree, the standard 24 Volt version used on the Kalkhoffs from about 2007 onwards, the S Class 24 Volt version or the latest 36 Volt Version? Just curious.
The reason for this Martin is that the old unit only had sprockets for 1/8" chain (single speed and hub gear), the later unit sprockets are thinner to include provision for 3/32" derailleur chain.On a side note, when I changed the front sprocket on a customers recently, the original sprocket was a little thicker than the new later Panasonic one, there-fore I fitted a very small shim behind the sprocket and then applied the cir-clip to hold it in place, without the small shim; the sprocket did wobble on the axle. The shim resolves this (Shim approx 2mm thick)
Thanks Flecc..The reason for this Martin is that the old unit only had sprockets for 1/8" chain (single speed and hub gear), the later unit sprockets are thinner to include provision for 3/32" derailleur chain.
Let me know the outcome on the dongle and I'll publicise it with you as the source for supply on my Panasonic support website
Hi flecc,I have real doubts that the dongle could work with the older first series unit as fitted on the Giant Lafree and earlier BikeTec Flyer models Martin. It was not only the speed regulation that was different, the power regulation method of the older unit was also.
So if Panasonic can do it, the 26 volt version would most likely be for the newer unit only, but that's no problem since the new unit outnumbers the old to a vast degree. Over six years Giant sold just 20,000 of the Lafree models worldwide. Derby Cycles alone probably sell as many Kalkhoffs as that every year and the new unit is used in more than 20 makes of e-bike.
As for the 26 volt dongle sales, they'll be most use to the derailleur geared bikes, since the hub geared bikes can be altered to just over 20 mph/33 kph just by a cheap change of the rear sprocket, and many have done that already. It's more expensive to do that with a derailleur and difficult to even 18 mph due to the confines of the top gear sprocket minimum size. I'd guess ebay could work wonders for the dongle sales, at least until rivals get hold of them too.
Even with 20mph/33kph assist limit, the range crashes by a third or more as many have found, so 50 kph would be a brief experience for most, especially so if using the 10 to 12 Ah batteries.
