Before I tell you what it has just cost me I was just wondering if maybe I am out of touch with LBS prices
Lynda
Lynda
LOLLynda you should have called me I would have done it for half the price.
I hope you are going to take the time to learn how to do it yourself because it is very simple. The back wheel takes a little more time and is a bit messy sometimes but the front wheel is a doddle.
I went to collect Jannie from work this week because she had a flat tyre. I was just thinking about charging her to fix the tyre. But I have just realised she was riding my bike.
Actually she can probably change it faster than I can.
Steve
Hi Steve,Hi Lynda,
I discovered something not so long ago called SLIME. It`s in a bottle which fills both front and rear tyres (inner tubes) and feels latexed based. It has a nifty tool to remove the valve and a bit of tube to apply the gunky green liquid into the tube. It seals any punctures up to drawing pin size. Before I found the product I was averaging maybe 3 punctures a month as I do a lot of canal towpath riding but in 4 months..none. I highly recommend this product. Halfords £10. They also supply a plastic/rubber tyre liner made by SLIME which increases the tyre wall thickness by a couple of millimetres adding to the integrity. I fitted these products myself but I`m sure a nice person at your local bike shop would help you out, especially if they supplied the materials as most do. Good luck Lynda, Happy twiddlin.
Steve.
