Good Conversion?
Andy88
747
135
69
Ayrshire
Saw this on youtube its a Spanish motor kit called ciclotek
How standard is this?
The makeshift mudguard under the bike
The Exposed wires
The U shaped cable to the motor to prevent water entering the hub?
See the blue bike wheel cable
Reactions: LeighPing
8,788
The splashguard is a personnel thing and added by the rider/installer.
The wiring from the 09 battery like that is normal as the pos and neg each has its own exit spaced about 8mm a part.
Finally the cable loop/drip is in most cases standard, it is only seen in the last pic if the fitter has no idea of what they are doing or fitted in error.
The XF07 hub is a bpm clone produced by Mxus.
