I like the motor, it is my first mid-drive and after 70 or so km on a full tank (10.4 Ah) and a couple of hills think it is maybe better suited to my terrain than the hub motor I have.
Mounting: follow the instructions and you could have a running bike in 30 minutes. My build thread is is in my signature bellow I took a little longer because I built the bike up from a frame and front fork. The bottom bracket had a couple of options for mounting and because of my choice of stand I had to choose the simple bracket.
I have the external controller version and the controller I chose isn't playing along but the only issue is the speedo doesn't work. cut off is set for 25 km/h and it does cut off about there because of my usual cadence.
If yours hasn't been re-greased by Woosh it would be a good idea to pop the cover and get some grease in there before mounting it. Mine had a reasonable amount of grease in it but now that it is packed it makes a little less noise.
The cranks I got, well they are black, the same colour as my frame...
The left one I have swapped for a Shimano forged crank already and I am working on getting the other of the chainwheel so that I have a matching pair of forged, not cast cranks.
If you have a natural cadence of between 80 and 90 you are good to go, my motor doesn't even get luke warm on my regular climb. You will love the way it helps you off the line and up hills. You just need to have the right gearing to maintain that cadence over your usual riding area. I need a lower first gear because I have the occasional section of 12-15% to be climbed. Chain line is good on my bike, not perfect but correct. I have had no issues with changing gears, no need to ease off or anything like that and no noisy changes.
Mount a motor cut-off switch because the PAS is very sensitive and if you move the pedals ever so slightly at a red light the motor will kick in. Could be embarrassing if you are in assistance level 5...
That is about it for now, as I said only 70 km done but probably a few more tomorrow.
