Hi Chaps,
I've been trying (and failing ) to remove the crank arm and chainset on my Haibike in order to try running a larger chainring.
I've discovered I need one of these Park Tool Co. » CCP-44 : Crank Puller for Splined Cranks : Crank Tools to remove the crank - it's not the old square section I'm used to.
However, the chainset itself then appears to be held in place by a large ring with 8 notches in it which screws onto the motor unit and holds the chainring in place. My attempts to loosen this with a drift and hammer in one of the slots has come to nothing.
Does anyone know of a specific tool that will do this job ????
Thanks, optimistically
