Hailong battery external fuse?
atheo
102
12
Beds..
I have a new 48v 17.5amh hailong battery with Panasonic GA cells.What rating external fuse should be fitted to protect the internal bms.
I ask because the bms has evidently given up,according to Jimmy at Insat and will have to go back for investigation.
The battery powers a 500w bpm rear hub motor.
TIA..Atheo..
wheeliepete
2,047
757
Devon
What controller are you using? Fuse rating and bms need to be rated to the max. current you are demanding from the battery.
3,994
The whole idea of the BMS is to protect the battery from over-current. It is the fuse, so you shouldn't need a separate one. In many of the batteries that use standard cases like that, the fuse isn't even connected.
