I'm working on converting my daughter's 1986-ish Peugot ladies tourer with an alien 36v kit which comes with pedelec and twist throttle (pics of our progress will be in another post). The bike has drop handlebars which she uses and would like to keep, but could be talked out of if it is too much grief to convert in a useful way. Her main requirement is assistance (some exercise required ) getting up the 1.5 mile 10% hill on the way to her new place of work. I've looked around the forum and seen some folk talk of converting touring bikes, but I've not found anything that helps me with some of the big questions:
1) Keep the drops?
All the alien fittings (twist throttle and brake levers w/ switches) are for 22mm bars and the bike has 24mm bars (15/16" in real units). The twist throttle could be replaced with an adapted thumb throttle - but where to put it for access from both riding positions without she has to develop an elongated prehensile thumb? The brake levers are a harder problem - I wouldn't want to use anything modified for such an important function. But is the cutoff switch really that useful - if you're going to stop you usually stop pedaling and wouldn't reaching for the brakes mean you release any sort of throttle?
Would the bike be usable if we didn't fit twist throttle or brake switches and rely on the pedelec (with an added positive enable switch for the pedelec - eg a press-to-connect, release-to-disconnect button; or perhaps in a twist?)
2) ....or replace the drops with straight 22mm bars? ...
All the 22mm handlebars I seem to find online are for motorcycles, but perhaps this doesn't matter? I'm also confused about stems/pins (used to call the whole thing a gooseneck when I was a lad) - 'stem' in the adverts doesn't seem to talk about the pin dimensions (which is 7/8" aka 22.2mm on the bike), and again I haven't seen one suitable for 22mm bars.
I'd be grateful for any light that you can shed!
Chris
PS I asked in my local bike shop; their response was that Peugot stopped making bike years ago and I'd be lucky to find parts. I'm hoping their view is because they haven't caught up with online buying....
1) Keep the drops?
Chris
