Yep, guessed as much thought I would give it a shot in the dark anyway.Typically the market for them will be scarce as they are a niche item.
One will need to open the wallet to buy one, even in used condition won't be cheap . 3k should buy you one, if one can find one.
It's is due to the controls, Hase Up has raised direct adjustable bars and stem adjustment, earlier models and many similar trikes like the eight trike uses indirect under steering controls.Up? Low seat.
Yes many not familiar with trikes don't understand used and may not be familiar with differing trike steering controls.Hi, it's a Trigo up delta trike.
