I want an opinion on this as i am not at work with a charger thats just gone pop.
There was only one light showing it has power, the charging light was off.
There was no fan spinning so i assume it wasn't working.
Where the kettle lead is plugged in, it sometimes buzzes when moved even slightly.
I took the plug out of the wall and has a look at the supplied power lead. This has a very strange fuse in it.
Now i don't know what the inside of a fuse looks like, but the end caps fell off and the case is made of some kind of plastic.
I can see through the whole thing.
Its rated to 5amps apparently.
I assume somehow this has blown.
I swapped this over for a regular pc 5amp kettle lead.
This caused the charger to go pop. The glass fuse inside the charger itself is still intact.
Does this sound like a faulty charger?
My bike is now stuck at work in the office.
