On that schematic, which is a little different to your controller, there's a spare connector from the controller with a battery voltage feed (the red wire) that the yellow wires's connected to. You can connect the yellow wire antwgere you want that has battery voltage, but ideally you want the lights to come on when switched on. I connect mine to controller side of the standby switch so that the lights go off when I put the controller in standby, If you put it the other side of the switch they'll be on all the time the main switch is on, or if you connect it direct to the battery, they'll be on all the time. The LED's use the black throttle wire as the negative, so the throttle needs to be connected for them to work.OK, thanks d8veh. Can you tell me how the yellow wire is connected to the battery in the schematic that JuicyBike posted? It looks like the orange wire connects to the yellow wire which connects to the throttle. What am I missing? Cheers.
The orange wire can connect to the yellow wire because it also normally needs battery voltage. Connecting them together is good because, as I just said, the lights will come on when the controller is active. The fact that you controller still works with the orange wire disconnected is unusual, so I can't say for certain whether it works as described.
