HUB motor dropouts question
Cam3roon2k41999
120
Hi,
On one of my posts I needed help on why my 3kw motor was rubbing against the frame next to the dropouts were the axle is,
My friend gave me 2 of these metal washer things what look like a C not sure what they are called lol
But now I have installed those C things on the inside of the dropout and then 1x tourqe washer on each side, 1x flat washer on each side and then the 2 tourqe arms and finally the nuts, its not rubbing anymore but I'm just wondering if the washers/nuts etc are on correctly?
Any answers would be appreciated, thanks
3,986
The C-washers are normally for front forks, where you have a dimple on the forks that doesn't line up with a normal washer. Plain washers would have been better, but C-washers should be good enough. The problem with plain washers is that you need special ones with a smaller outside diameter so that they don't rub on the freewheel.
Cam3roon2k41999
120
Ahh yeah makes sense actually, seems to do the trick for now haven't riden it yet though lol
Also I know I've asked this before but will having 2 tourqe arms fitted be safe with aluminum frame as my other bike the dropouts snapped but I didn't have any tourqe arms on what a idiot I am lol
3,986
Two torque arms should be enough, as long as they're fitted properly. Show some photos if you're unsure.
