Hydraulic BRAKES
garysnooker
130
LOOKING TO BUY Hydraulic Brakes just wondering what BRAKES TO BUY TO MAKE IT A easy JOB TO STICK THE brake lever sensor ON
17,268
Tektro M285 are the easiest to fit hydaulic brake sensors to. This is on one of my old bikes:
6,722
if you have decent hydraulic brakes you dont need motor cut off sensors ;)
8,762
No you simply buy a new controller each time you blow the mosfets.
WheezyRider
1,690
938
Is that a reed switch in the sensor head? Did that come as part of a kit, or did you have to put that together yourself?
17,268
you can make your own with off the shelf reed switches but they cost only about £16 a pair of ready made sensors, it's not worth the effort making your own. I put a 2mm screw on the magnet because I don't trust the sticky pads that come with the sensors.
Reactions: WheezyRider
StuartsProjects
1,852
1,040
I did the same, first positioned the magnet with a bit of double sided tape. Adjusted position so that it switched correctly. Then drilled a pilot hole throught the hole in the centre of the magnet and secured it with a small self tapping screw.
53247
8,762
This 4 piston brake set has integrated sensors, if the three pin julet type connection isn't wired correctly it come with an adpater to sm 2.
The sm2 connection would be compatible with sm capable controllers .
4-piston Electric Bike Hydraulic Disc Brake Kits Front and rear hydraulic disc Brake 4-piston calipers (risunmotor.co.uk)
If you use a KT controller then brake sensors aren't needed , as there is nil over run.
They are handy though if you have a throttle which could go wrong.
