I thought it might be of some use to readers of this forum if I posted the end result of my problem with a new controller not working with my existing 750w hub motor. The testing was originally posted on here on a couple of other different threads.
I've found I can no longer assume that a hall effect controller from one supplier will work with a hall effect motor from another supplier, even when voltage and wattage are carefully matched.
I wanted to upgrade to the new controller to get variable PAS and a better LCD panel, but I've now had to revert back to the original more basic controller, and have wasted £75 on the new one.
All possible tests were tried, and even some by d8veh who very kindly offered to check as well. The supplier even very promptly sent a replacement unit from China, free of charge, but that failed to work with my motor as well, and acted exactly the same as the original unit.
So I realise I've just been lucky up to now with my "mix and match" purchases for my other bikes that worked fine with the upgrades.
