My Ezee Forza has developed a bit of a knock - clonk or whatever from its lower regions and I am reluctant to start dismantling it in case I have not correctly identified the problem.
The clonk occurs when pedalling - light cadence pedalling is ok but the clonk is distinct when putting pressure on the pedals up slopes - into headwinds etc and can be felt through the pedals. My natural thoughts were it was the cranks or the bottom bracket bearing although checks show there is no obvious wear, play or movement in either the pedals, cranks or bearing. There is no kink in the chain and the rear derailleur appears ok. Perhaps my manual checks can't reproduce a minor bit of play in the bearing but I would like to sort it if anyone can offer ideas.
Whatever I am enjoying the bike and have now done around 600 miles on it since July.
Cheers
Cheers
