Kalkhoff what cog?
lemmy
I have a Kalkhoff Tasman which has the 8 speed Shimano hub. I'm planning to fit a rapid fire change instead of the twist, which tends to be a bit awkward to use under the constant gear changing needed in London.
I thought I might try a gearing change at the same time. I find the gearing a little too low but I don't want to lose powered range.
For the Agattu 7 speed, many people recommend a 19 tooth rear cog. Would a 20 tooth perform a similar function on the 8 speed?
I'm using the bike in west London and environs, Epsom Downs and so on, so I don't want to lose too much hill climbing ability. Essentially, when the power cuts out at 15mph, by 18mph the old lallies are spinning too fast for comfort.
Any experiences anyone - specific to gearing on the 8 speed, of course?
30,850
The 8 speed needs to be lifted more really, since it's greater gear range is all added lower on the Panasonic equipped bikes. A 20 tooth will raise your motor assist limits by 1.5 mph and the change in the bottom gear climb ability will barely be noticeable.
A 19 tooth will raise the assist limits by 2.4 mph which I think is more useful and I can't imagine not being able then to climb a hill in those areas in bottom gear on the 8 speed hub.
Barry Heaven
162
I fitted a 19 tooth sprocket on my 8 speed Alfine hub Pro Connect and it feels just right now. It did lop about 1/3rd off its range though.
lemmy
Thanks for that. It's a bit of a headache, I want the higher gearing but not to lose the range - something for nothing, in other words.
30,850
With maximum power at up to a cadence of 40 which corresponds to 9.4 mph in top gear on the standard 8 speed setup, in bottom gear that's just under 5 mph optimum climb speed at a 40 cadence, though you can climb slower still with maximum power at a lower cadence.
Changing to the 20 tooth sprocket lifts that maximum power climb speed at a 40 cadence to 5.4 mph, with a 19 tooth to 5.7 mph.
You can see that the effects at the bottom end are not severe and you should still be able to climb almost anything just the same.
