I'm getting a knocking noise when the bike is either under power or just coasting, with to without battery fitted and it does not make the noise if the wheel is lifted off the ground.
I have ruled out the brakes and I have also loosened up the hub nuts and pinched them tight to rule out them being overtightened.
The spokes all seem tight enough but then again they are under a lot more strain with me sat on the thing.
I'm only noticing these things after the trouble I had with badly set up brakes as I am being more critical. The bikes running well but the noise is bothersome.
Any ideas? ... Am I worrying about nothing?
