KT LCD 3 throttle settings
djah
55
Hi guys. Just a couple of questions in relation to the above.
Is there a way in settings to reduce the delay between operating the throttle and when it actually kicks in? It’s seems to be a second or so currently.
Is it possible to reduce the power delivery from the throttle?
I’m just getting herself used to the ebike. It’s got a 500W rear hub motor with a 48V battery. This does give a fair kick if twisted too far.
Thanks.
8,752
The parameter settings aren't as sophisticated as the Bafang BBS where you can plug it in to PC to change software settings. You can reduce current using C5 which will affect torque and all pas modes as well as throttle.
The throttle you get used to but I now only use throttle after pedal activation.
pn_day
185
40
St Andrews, Fife
djah - the manual contains P and C parameter settings. Depending on which version of the controller you have, some of the C settings may not be present.
Worth a search online if you have a unit that includes C13/C14 settings - mine doesn't.
8,752
C13 & C14 are for regen braking or pas tuning signal strength, won't have any bearing on throttle lapse/delay.
