I recently picked up a second hand Kudos Tornado which had a fault.
Although the display worked, the speedometer wasn't registering and assist was limited to one level - the buttons on the display to adjust assist level appeared to have no effect other than changing the number on the display.
On getting home and "fiddling" with a few things (connections etc) the display started showing Error 30 - which is a communication error. Searching shows this is likely to be either:
a) Dodgy wiring
b) Broken display (J-LCD King Meter)
c) Damaged Controller
The slight smell of burning from the controller box led me to believe the problem was likely to lie with c).
On opening up the controller I found the following:
There are burnt components on the left hand side in the first photo.
So I assume the controller is toast and I need a new one.
The last photo shows the details of the currently fitted controller. Maximum current is 14A. I would quite like to upgrade to 18A if possible for a bit more grunt.
So please can anyone recommend me a controller that is:
a) Compatible
b) reasonably priced (this is meant to be a cheap project!)
I don't mind waiting for it to be shipped from China, ideally I want something that is plug and play (there are "lots" of small black plastic clips).
Any help appreciated - the plan is to fit a new controller, see if it works. If not, I will check the wiring and then move on to a new lcd if necessary.
a) Dodgy wiring
a) Compatible
