I've got the broken off bit but didn't think it would glue well on the bend but i see from watching youtube on the uv glue you linked to i can build up layers so will give that a go cheers.If you've got the broken off bit, you can glue it with UV glue.
10ML CRYSTAL REPAIR UV RESIN, GLUE FOR GLASS, METAL, FURNITURE + 9 LED UV TORCH | eBay
It is best to cure in layers, uv light need to penetrate in to uv adhesive, use a small amount first cure it with uv source, repeat the process. If uv light doesn’t reach the uv glue YOU CAN NOT CURE IT.www.ebay.co.uk
Clean carefully with meths first the areas to be glued, for maximum strength, and do not touch with your fingers. Fingers are fatty!I've got the broken off bit but didn't think it would glue well on the bend but i see from watching youtube on the uv glue you linked to i can build up layers so will give that a go cheers.
Thanks if the uv glue doesn't hold then i will look into using a clamp as you suggest.Clean carefully with meths first the areas to be glued, for maximum strength, and do not touch with your fingers. Fingers are fatty!
If it does not hold (it really should if properly done), then cut off the whole of the damaged "ring", and find a metal "bridge/Clamp" that will fit your handlebar, and glue the top bit securely to that! Possibly from plumbing supplies. Or make one from a piece of flat copper or similar, and a nut and bolt. A piece of rubber under it will help to prevent movement.
A wide but short hose clamp may work. See here:-
regards
Andy
