Left Handed Cateye BM500 mirror
30,850
bit pricey with the postage, but better than a blind side.
Not too bad even with that postage Beeps. Their dollar price for the mirror type equal to about £3.31 compares with £9.99 in the shops here for that mirror type or £8.88 from Wiggle, so only a little dearer overall.
An alternative dodge is to use one of that type of right hand mirrors upside down on the left, underslung. That works well with many straight handlebars. Depending on how your arm sits on the bar, the inward crank of the mirror arm often allows a clear view.
Beeping-Sleauty
410
Colchester, Essex
..... An alternative dodge is to use one of that type of right hand mirrors upside down on the left, underslung. That works well with many straight handlebars. Depending on how your arm sits on the bar, the inward crank of the mirror arm often allows a clear view.
Good tip Flecc, i did try the under-slung position, but couldn't find a good point on my butterflys, at the high point the bars blocked the view, at the low point the mirror is too close & too low.
It's a shame the fixing point on the back of the mirror isn't double sided, if you know what i mean, then the mirror could be used both sides of the bars.
30,850
No, it wouldn't work on the butterfly bars, mostly fairly straight bars being suitable. I agree it would have been better if the mirror had been designed reversible.
In fact I prefer to use the BM300G, as also seen fitted here, though it means I have to file down the fatter plug in part and also notch the outer ring to allow the mirror to tilt further out to get a clear view.
With that I don't need a L/H mirror since the R/H one gives a sufficient view on both sides to the rear. In my area I have one cycle lane out in the road with traffic lanes on both sides, the L/H one being a combined bus lane between two stops and a slip road from a side road that joins it. I find I can see when a bus or car are approaching from the left and am able to wave them through with my left arm since they are often nervous about overtaking a bike on the left, particularly when traffic is passing on the right as well.
Nick
152
I've had a Mirrycle mirror for a few hundred miles and it's faultless - doesn't vibrate, stays in place, and gives a clear view. I know Evans Cycles do them but think I got mine from somewhere else - not sure where.
burncycle
639
Sheffield
Got mine from Halfords.
I think they have these in too.
Nick
152
I think it could have been SJS I bought mine from, and I meant to say that it can be fitted to either side.
