Lishui controller
scott gaza
162
24
scone
Hi all, i am trying to find a Lishui controller for sale. i have a Lishui 36V 250W 6MOSFET controller with a KD21C display im sure the controller is starting to play up!
8,788
What issues are you experiencing ?
scott gaza
162
24
scone
Thanks Nealh, in the past week my bike was dying soon as it started , then it was fine for a little while then only gave half power. Now it is not responding the display seems fine and pas light flashing. Gaz
8,788
Lishui are OEM only so you won't willy nilly pick one up, you can try Woosh bikes as they use them all the time. The issue though is that they are usually programmed to the suit the motor they are used for and parameter aren't changeable like KT.
Have you checked battery voltage at all with a meter ?
Also possible the display/lcd is at fault, to rule out a faulty display you can short out the wires on the connector but we would need to see a pic of connector/wire colour.
scott gaza
162
24
scone
Thanks again Nealh, i will contact Woosh, I know juicy have one but want £59 for a controller and £79 for a display My Scottish blood would boil :). My battery is still good i have done just over 2000 miles on it. its is a year old panda kit and all wires are inaccessible except for opening up the controller its self. looks like i will have to get new kt system any good ones around you could recommend? i would buy another panda kit if i you could buy one without the battery. Thanks Gaz
8,788
Contact Woosh first as a new KT controller/LCD etc will be in the area of 75 -100 pounds.
Reactions: scott gaza
