I have opted for the HS33 brakes and they arrived this morning.
Fitting was going well until I have come to the removal of the existing Shimano V brakes.
Item 1 here, the Link Fixing bolt is insanely tight. This is compounded by the fact that it is a hexagon socket head bolt which is somewhere between 5 and 5.5 mm. My 5 mm wrench feels just a little bit too loose and the 5.5 mm is too large to fit in. I don’t think there is a 5.25 mm and it is unlikely to be an imperial size. The actual depth of the socket is very shallow too (much less than an expected 7.5mm minimum), which makes matters even worse.
I know by feel that the 5 mm wrench is going to slip and chew up the inside of the socket. If all else fails I’ll drill the head off the bolt and use a stud extractor to get the rest out, but this isn’t a very pretty option.
Has anyone removed these bolts before and if so how did you manage it?
Tom
