Here is my new bike. A Marin Muirwoods 2009 model. I got this at a bargain price and luckily for me it was the last one they had.
I like the look and design of these bikes and have been looking at these Urban bikes for a while. It has a lightweight mountain bike frame, skinny kevlar tyres TruvativDeore gears with an outer ring of 48 fairly for high speed.
I've been getting used to it for a few months now while i decided how and what i 'm going to do it. I was going to build the bike as a crank driven hill climber with frame mounted motor driving the 28 tooth ring and the outer two ring sets 38/48 for pedalling speed, hence careful choice of bike that had the chainset gears i needed. However i have decided against it completely. Not that i can't engineer it that way, i figured my fitness level has increased so much the combined effort of front mounted tongxin motor and me can get up most hills.
First stage is fit the hub motor. The Marin wheels are Alex rim double walled with 32 holes so rather than get a new 36 hole rim and lace it up, i simply took the wheel off my old creaky worn out Claud Butler bike.
This wheel has a Tongxin 260 rpm motor into a 26" wheel to give's a 'nice' speed.
I couldn't have a shiney aluminuim wheel when the rest of the bike is matt black, so i waited until i had a few things to paint, etched primed the wheel and shot some matt black over it. Looks rather stealthy at the moment, can you see the fibreglass mudguards? i couldn't buy any i liked for narrow tyres, so i made some.
mmmm...could be the theme of the bike? not sure yet.
This weekend i tried out it's freewheeling ablitilies. How about 35mph down hill, no pedalling. These Tongxins have hardly any noticable drag, you hardly know they are there.
I have a 36Volt 5ah Ping battery on it's way, and i will add another 5ah from my wifes bike whenever i need to ride some distances. I have a few tricks i want to try out, but need to house all the electrics.
I came up with this photoshopped permanant box arrangement in the middle of the frame. Although i can keep it very narrow(width of batteries) i am beginning to think it looks a bit ugly on a nice looking bike.
I thought it would be good to have a housing that would have the capabilties of carrying serveral batteries, controller, switches, current limiter, power analsyer and charger, all safely locked away.
I will tig weld the housing together and paint it matt black to match the rest of the bike.
I rigged up the electrics a few days ago (battery and controller in my rucksack). Immediate problems i encountered was having the throttle and brake levers all fighting for their respective position on the handlebars. I could put up with that on my last bike, but want a proper solution to this one. First thoughts are thumb lever or different gear shifter or even a simple on/off trigger on a micro switch
I'll post some more photos as the project develops.
Mel
Mel
