Met Police officers receive training to identify non-compliant e-bikes
Sparksandbangs
51
16
Met Police officers receive specialist training in Oxford
Seriously? Five days?
30 minutes would be enough with time for lunch included.
Rider wearing a balaclava - Dodgy
Scooter in non trial area - Dodgy
No pedals - Dodgy
Dinner plate rear - Dodgy
30mph uphill - Dodgy
That should take care of 80% of it.
3,768
What are they expecting to find inside the motor? Are they going to check the number of turns on the coils in case someone rewound it? They should have come to me for training. I reckon I could've covered everything in about 4 hrs.
StuartsProjects
1,849
1,039
From my observations, if the rider of an eBike is carrying one of those square food carriers on their back, there is a very low chance that the eBike is legal.
You could train police officer to be aware of that issue in just a few seconds, no need for a 5-day course.
Sparksandbangs
51
16
I suppose there is a possibility that someone has opened up the case previously and stuffed some extra watts that they bought on eBay in there.
Reactions: AntonyC
3,347
The training included an identifit for a Mr.Watt? I guess after such thorough specialised training, these fine orifficers are deemed ebike experts, and thus there won't be any need to consult more troublesome experts when prosecuting, or something.
portals
774
228
On a more serious note maybe they could stop the jollies and just use their own powerpoint presentation.
Slide 14 with the generator is fascinating.
When cops learn how to turn up at work without their breakfast on their uniform I might comply.
You're average run of the day bent copper's mind will be blown by slide 4.
Benjahmin
2,650
1,776
70
West Wales
Fortunately my bike looks nothing like any of those pictured in the pdf. It's good to see that officers are being made aware of the 2016 law change, now I've got to go and find the 2014 receipt for my bike and the kit.
My remaining concern is that the Ezee motor has no markings on it at all.
3,768
Didn't you post details of your bike on the forum when you first got it? That should be sufficient evidence.
Sturmey
699
374
68
I wonder can you just mark it yourself as seems to be suggested below.
EAPC marking
If the EAPC doesn’t have a plate, it should be visibly and durably marked with the:
  • manufacturer’s name
  • maximum continuous rated output of the motor
  • maximum speed at which the motor can propel the vehicle in mph or kilometres per hour (kph)
30,778
Of course you can as long as the marking isn't fraudulent. You'd have to be able to justify it, if asked.
Be careful if you are claiming pre-2016 rights for your EAPC. The rules for marking earlier bikes were different, todays rules on the plate will tend to indicate your EAPC is very recent:
http://www.legislation.gov.uk/uksi/2015/474/pdfs/uksi_20150474_en.pdf
Clarification from the above link on the specification plate required on pedelecs
Plate (a) (i) is only for the historic e-bikes from before 6th April 2015.
Plate (a) (ii) is for all pedelecs since that date.
Confirmed as below by James Brown, International Vehicle Standards, Department for Transport:
"As part of the GB EAPC amending legislation, that will come into force on 6 April 2015, the requirement for the marking identification has been amended. Previously a plate showing the manufacturer, maximum continuous rated power output and voltage was necessary, from April 6 2015 the requirement will be that the manufacturer, maximum continuous rated output and maximum assisted cutoff speed shall be marked on the cycle."
This should be in the form of a plate or permanent label bearing all three items of information, mounted in a prominent easily read location on the bicycle.
Benjahmin
2,650
1,776
70
West Wales
'Sfunny how memory plays tricks ain't it? Having just looked it up, my Ezee kit was first put on a bike mid to late 2015 and that was a different bike to the current one.
So, all in all I'm starting to think it's time for a new kit (can use the same batteries), maybe a new bike if I can find one with decent sus forks.
3,768
Lots of things to think about because there are so many choices.
