Thanks. Does this power automaticly decrease or should i always stop it myself?1000W is the nominal power of your motor and peaks of 1600W are okcas long as only for a few seconds at a time.
My Dillenger 1Kw motor and s the same.
but its not dangerous for the motor or controller to go to these values when the motor is rated for 1000w?If the motor keeps putting out 1600 watts I would refrain from touching the throttle by around 80 kph. It would be really scary by then.
Don't worry about the peak values. Unless you maintain it for a while ( usually thinking around 30 mins) the motor won't overheat. If it starts to get warm stop and let it cool off.
But I don't think that your battery or setup will let you do that.
Ride and enjoy.
i have put the limit on 57kph and it can reach that. I dont actually want to go faster then that.About 45kmh for 1000W, can't see you going over 50kmh.
