hello and thank you first of all,
i have a stealth bomber frame with a 150a controller on a 8000w motor and i have purchased it off of someone and im trying to upgrade it a little bit.
what im trying to do is use the full potentional of the battery and controller by letting it use the maximum amps the controller can give.
i think my battery might be 100a BMS, if so then i would buy a battery to get past the 150a controller limit.
would anyone be able to tell from what is already set on the settings? im kinda new to this so im learning alot at once, i presume its 100A with the
setting already, DC/Boost Current being at 100. but just wanting to be sure and double check before i order anything.
many thanks in advance
