Hi Riche
If you have the shrink covered battery no charger is included
What BMS did you spec in the battery as there are 3 options the standard battery only comes with a 10AMP BMS
Also what size motor have you if you have the wrong BMS it will cut out with a large motor and controller
We are awaiting delivery off chargers about 2 weeks we sell 48 volt 4 amp cost £95 + £5 postage
we also supply fitting kits with proper dropout adapters and spacer washers all laser cut from 6 mm steel
different kit for front or rear you need these with powerful motors or you will destroy the front or rear forks
if you send me photo off the end off your forks i can supply the right kit
Also can you keep other members updated on the service and delivery times on your kit so they can buy from there and how you get on fitting the kit to your bike
PS all our kits and bikes are NOW 48 volt More fantastic GRUNT
Frank
Hi Frank,
Yeah its a shrink covered battery, I had to select the 30a option , the motor is 500w rear wheel.
I am interested in the dropout kit where can I see/buy it? I will do a thread on my build with photo's, but I am missing a few odds n ends atm.
The kit has arrived it took about 4 weeks, main delay was the battery being built as I understand it, even though it was all supposed to be in stock. It pays to get the online BMSBattery help to look at your order and check your getting the right stuff.
I will get you a photo tomorrow of my dropout and the bits BMSBattery have supplied.
Thanks for your help
Richard
