need info on settings
billyboya
988
88
72
uk
Could someone here explain in easy detail what all these settings do on my bike, I know quite a few But not all. it seems the total miles I have done since having the bike just totals up isnt there a setting to place back to 0 as I like to know how far I have travelled on each trip
many thanks
P00: Restore Factory Settings Set this value to 10 and switch to next setting, the display items will show all contents and restore original factory settings.
P01: Backlight Brightness (1: darkest; 3: brightest)
P02: Mileage Unit (0: KM; 1: MILE)
P03: Voltage Class 24V / 36V / 48V
P04: Sleep Interval
(0: never, other value means display sleep interval) Unit: minute
P05: Power Assist Gear
0/3 Gear Mode: Gear 1: 2V Gear 2: 3V Gear 3: 4V
1/5 Gear Mode: Gear 1: 2V Gear 2: 2.5V Gear 3: 4V Gear 4: 3.5V Gear 5: 4V
P06: Wheel Diameter Unit: inch Precision: 0.1
P07: Magnet Steel Number (for Speed Test) Range: 1-100
P08: Speed Limit
Range: 0-50km/h, parameter 50 indicates no speed limit.
1. Non-communications status (panel-controlled)
When the current speed exceeds the speed limit, the PWM output will be shut down; when the current speed falls to lower than the speed limit, the PWM output will be activated and the driving speed will be set as the current speed ±1km/h (only applies to assist power speed, not applicable to the handlebar speed).
2. Communications status (controller-controlled)
The driving speed will be kept constant as the limited value.
Error Value: ±1km/h (applicable to both the assist power/handlebar speed)
Note: The above-mentioned values are measured by metric unit (kilometers). When the measuring unit is switched to imperial unit (mile), the speed value displayed on the panel will be automatically switched to corresponding imperial unit, however the speed limit value in the imperial unit interface won’t change accordingly.
P09: Direct Start / Kick-to-Start Setting
0: Direct Start
1: Kick-to-Start
P10: Drive Mode Setting
0: Power Assist – The specific gear of the assist drive decides the assist power value. In this status the handlebar does not work.
1: Electric Drive – The vehicle is driven by the handlebar. In this status the power gear does not work.
2: Power Assist + Electric Drive – Electric drive does not work in zero-start status.
P12: Power Assist Intensity Range: 0-5
P13: Power Magnet Steel Number 5 / 8 / 12pcs
P14: Current Limit Value: 12A by default; Range: 1-20A
P15: Unspecified
P16: ODO Zero-Out
Long press the up key for 5 seconds and ODO value will be erased.
P17: (Customer Designated) Auto Cruise Option. 0: No Auto-cruise
1: Auto-Cruise On. Trigger time of auto-cruise is decided by the controller.
P18: (K5S, APT Protocol Bound) Forward / Backward PAS Option.
0: Forward. 1: Backward.
P19: (K5S Protocol Bound) Throttle Level Option.
0: No throttle level. 1: Has throttle levels.
P19: (K5S Protocol Bound) 6km/h Cruise Throttle Definition. 0: Throttle has no 6km/h cruise definition. 1: Throttle has 6km/h cruise definition.
3,009
You could reset the odometer after every trip, which seems to be:
P16: ODO Zero-Out
Will also come in handy when you sell the bike, with zero miles on the clock ;)
billyboya
988
88
72
uk
Thanks guerney will try that, I'm also searching the net for other functions I have asked the company too
I893469365902345609348566
533
128
many thanks
P04: Sleep Interval
P08: Speed Limit
0: Direct Start
1: Kick-to-Start
P15: Unspecified
P16: ODO Zero-Out
This post may be useful -
533
128
Settings appear similar although this is a different display -
