New Shimano products
17,316
definitely high end.
would they be reassuringly expensive too?
17,316
shemozzle999
2,826
686
Auto shifting to maintain maximum motor efficiency and battery range - whats not to like?
Expensive for Europeans;)
Reactions: LeighPing
17,316
automatic shifting: a solution looking for a problem?
it seems they want to make a bike to be driven instead of ridden.
while we are still talking about banning the twist and go throttle.
30,847
I've long favoured a wide range 5 speed for e-bikes, so it's good to see a new 5 speed hub. The SRAM P5, tough though it was, had ridiculously slow down shifting.
Just a pity it's only automatic at present but hopefuly we'll get a manual version later to increase sales.
grldtnr
627
288
south east Essex
Yes, Flecc, hub gear/disc brake would be a good combo.
But I can't help thinking bikes are supposed to be simple, what's with all these gadgets to solve a problem, the problem wasn't there in the first place?
But it is a case that there for once is something new in cycle design, most things have been thought of before, and I am guessing that auto gear change has been there before.
.....and yes it had ,the Nuvinci hub!
30,847
Actually Shimano beat NuVinci to it. Their first auto shifting gear was a three speed long before the NuVinci launch, used on some utility bikes and highly praised. They later followed with an auto shifting 8 speed hub and more recently auto shifting derailleurs at scary prices.
Another company, Baron Controls markets ProShift. The system is compatible with the Shimano Di2, SRAM eTap, and Campagnolo EPS electronic groupsets, with shifting controlled by a head unit that is connected to the groupset. This head unit then takes your riding data (speed, cadence, heart rate and wattage) to determine your optimum cadence, and then shifts into the appropriate gear.
17,316
The industry sees e-bikes as a luxury item, not a mean of transport. You have parallels: QLED TV with 2000 'nits' instead of just HDTV.
gear shifting has never been an issue before the introduction of the Bosch CD bikes. if you want simple, buy a geared hub bikes.
5,786
Gear shifting isn't a problem with your GSM!
Just wanted to say... :)
