I just acquired this Nihola cargo trike for a rather good price
It's got a few dings and dents, but hardly any wear on the chain and tires.
The promo vinyl came off nicely yesterday, and a child seat is about to be ordered.
It's rather hilly around here and the missus is not really an avid cyclist, so I need to do a proper conversion.
It would be great with some feedback before I go and send all that cash off to China..
The plan so far is to use a Bafang BBSHD and mount it inside the frame if possible.
( Someone mentioned the bbs02 was not rainproof if mounted too close to upside down.)
It seems that 1000W is the standard for this motor, so it's probably not worth considering the smaller versions.
48V also seems to be standard, and I guess I should get at least 15Ah..?
And I should probably get a gearsensor, and a programming cable of course.
But what about sprockets and torque...? That's kind of outside my field of experience..
Its now got a 38t sprocket front and 22t rear and an SRAM P5 hub with coaster brake.
Presumably it's the cargo model in which case some of the the specs are:
Torque/driver body: max. 85 Nm.
Ratio 224% (0.667, 0.778, 1.000, 1.286, 1.500)
The motor comes with 46t but I see 44 in some listings.
Its possible a 24t would fit on the hub, but maybe I should try to get below 40 in front instead.
Or perhaps that would risk overloading the hub?
Well folks, I could carry on, but what do you think, am I on the right track here?
