normal thread
ArthurR
10
85
Scotland
Hi I am Arthur I am 77yrs. old and have been riding all my life. A couple of years ago I found that age had caught up with me but I did not want to stop riding so I went electric to help me get out on the road. Unfortunately I had a heart attack last August and now am not as steady as I was but I still want to get out biking if possible so I bought an electric trike which seems quite good. However I was informed that They would not supply one with a throttle owing to new regulations. I have been told that I should be able to fit a throttle to this unit and was wondering if anyone could explain how this can be done. I have had a look in the housing where the controller is and there is one connection that is not used in there It has a larger white connector on with 2 pins inside. There is a back wire and a red wire leading into this connector. and I was wondering If this was originally the connector for the throttle. It would be great if someone could give me some info on this. By the way I think the unit is a BAFANG as the no on the hub motor iBFSWXB36v250w 170R. Thanks Arthur
Gaz
720
556
55
Eastbourne
Hello Arthur :)
Can't help you with the throttle electrickery, so it's just a hello from me. Someone'll be along in a bit who knows the clever stuff, I'm sure.
Gaz
ArthurR
10
85
Scotland
Hello Arthur :)
Gaz
Thanks a lot its good to know I've been noticed though thanks for the welcome Art.
Reactions: Gaz
30,863
A throttle normally needs three connections Arthur, 5 volt, ground and signal. This is probably one for the experience of d8veh and hopefully he'll spot the thread. Meanwhile if you are able to post a clear photo of the controller internals it might be helpful in determining whether a throttle is possible,
Reactions: Nealh
8,804
Throttle as flecc has said has 3 pins/wires. A pic of the controller and wires from the controller nicely spread/layed out will be of great help.
ArthurR
10
85
Scotland
Thanks for the note I am not sure how to post a picture though still struggle to get around the site you will have guessed that I am not very good with I.T. Still thanks for the interest and taking time to answer Arthur
30,863
When you post a reply Arthur, there's three buttons at the foot of the reply box. The middle one is Upload a File, so you can use that to navigate to your photo on your computer etc and then upload it, following the instructions. Then finally use the Post Reply button.
ArthurR
10
85
Scotland
Hi flecc you are being very helpful will need to look at it tomorrow thanks again for your time and info Arthur
Robbieg
188
71
67
Burton on trent
Hi Arthur,. Unable to help with technical advice although there are plenty of knowledgable members able to; good to see that recent health problems hasn't dampened your enthusiasm to keep getting out on the bike so good on ya !
Reactions: mw1
KirstinS
3,224
899
Brighton
Hi Arthur and welcome
Is the controller housing separate from the battery holder or contained within it (again pictures speak a thousand words !)
The reason I ask is that if it it is separate AND for some reason your current controller won't accept a throttle then you could change to one that does not very little money. Batteries are very expensive, motors a little expensive , all other parts are pretty cheap. And your motor is very common one so easy to find new , compatible parts
Cheers
ArthurR
10
85
Scotland
Thanks for the reply and compliment. I have started to build another Trike and add a motor to it with a throttle but thanks anyway. Arthur
ArthurR
10
85
Scotland
Cheers
Hi Kirstin thanks for taking the time to respond. Your suggestion sounds great I never thought of going down that route. The controller just sits in a compartment at the bottom of the down tube. I think it is completely separate as you can just pull all the plugs out and it is free. I think the reason that it won't accept a throttle may be the fact that new regulations don't allow new vehicles to be fitted with a throttle. However I decided to go down a different route I have bought a new trike and have just bought a Golden Motor Magic Pie 4. Daft isn't it but on this unit I had to pay extra for the PEDLEC as this only comes with a throttle as standard. (Total turnaround.) A bit more expensive than your idea though. In future though I may try to upgrade to the Bafang mid drive system if it will fit on the Amacco Trike. Thanks again for your help I may still look into it then I can have a spare trike if I wreck one . Best wishes Arthur.
