I'm glad you've got it working. Now that I remember, I had the same with Saneagle's CST motor. With his, I knew the controller because it eas the same as mine. When it didn't spin, I spun the wheel by hand, and it sprang to life. I think the self-learning sequence in the controller must get confused or something. I'm pretty sure that as long as the hall connector is connected, they try and run in sensored mode, because, if you pull a pin on the connector, they don't work.
