Inner tube selection & pressures
Also follows a number of recommendations for Marathon Plus tyres - also good, probably (and I have the re-assuring glow having them supplied as a standard item on my bike), but would M+ Tyres have prevented this?
Ratzakli did not get a thorn, he hit a small but deep pot hole which caused the inner tube to burst. Are we saying that the extra rigidity of an M+ (or similar) tyre will also help prevent inner tubes bursting? If so, double warm feeling cos I cannot avoid hitting some potholes myself everyday - especially when the choice is pothole or front grill of bus/truck! But isnt there also something here about the quality of the inner tube and the tyre pressures?
I dont know what inner tubes Ratzakli had, or what ones my bike has as I have never seen them, but I generally keep them pumped to 60psi, front and back, which gives minimal rolling resistance and I can just about cope with the rattles and bumps.
Am I more or less likely to have an inner tube burst after an angry pothole with higher or lower pressures, and if I do need a new tube - which ones are least prone to bursting?
Just curiuous that an inner tube bursting leads to recommendations for M+ tyres. (The benifits regarding thorns, glass etc I obviously understand as well as the idea that if you are taking a wheel off, then thats the time to change a tyre if you are going to do so)
All the best
Bob_about
Excellent that there then follows some very helpful advice for Ratzakli and others on how to remove the wheel to replace the tube, which it sounds like has done the trick - fantastic....... until this afternoon that is, when I managed to come face-to-face with a small but very deep pothole!![]()
I spotted it at the last moment and just managed to lift the front tyre over it but, of course, the back tyre hit it with a heavy thud and immediately burst the inner tube.
Ratzakli
All the best
Bob_about
