I found an old SD card with literally thousands of my old ebike photos on it. Some of them were for projects I posted on here, and there were lots of other interesting ones too.
Here's an ebike I spotted in the town centre. A couple of things stand out to me. It seems to have a cable operated hydraulic brake on the back 6 years ago. I didn't know they were around then. Look at the mount. Is it home made? Also the arrangement for holding the front wheel looks weird. I can't make it out. I should have looked closer at the time. Finally, the front brake looks like a standard cable disc brake that's badly adjusted and about to go over top dead centre, which would be a real problem for that bike with all that weight travelling at 30 mph:
Next, is a Gocycle that I repaired. This photo is of the inside of the chaincase, which is much more complicated than it looks from the outside. You can see the nice chain tensioner and the R/C servo that's used to do the automatic gear shifting. That was the thing, which was faulty and needed replacing:
