I'm sure I've read in an 11t motor sprocket thread that swapping from the 9t to an 11t gives a proportional decrease in power output, but I don't understand how that can be the case. I've written my understanding below. Am I missing something?
Panasonic system gives power according to;
1. Which mode it is in high, med or low.
2. Rider input to pedals through torque sensor.
3. Cadence. But it doesn't actually measure cadence rather it measures motor speed, which is directly proportional to cadence. The actual proportion being determined by the motor sprocket size with 9t as standard.
With 9t max power output is at a cadence of 39 RPM and it reduces to cut off at 60 RPM cadence.
Swapping for 11t will move max power output and final cut off point up the cadence RPM by 11/9. ie max output at 48RPM tailing off to cut off at 73RPM.
If the top gear of the bike remains the same then this will result in an increase in the speed at which motor will assist. ie up from around 15mph to 18mph.
Complete legality could be restored by reducing top gear, but would result in reduced ability to ride above assist speeds.
I take it it's the motor assistance at higher speeds which reduces battery range as it does when changing the gearing to higher than standard?
I don't see how the power of the motor is affected other than as stated above.
