Panasonic Ebike Motor Identification
tillson
5,253
3,197
Can anyone help me ID these two Panasonic motors. I would like to know the voltage and the year of manufacture mainly, but anything else which can be derived from the photos would be useful.
Sent from my iPhone using Tapatalk Pro
The first one is dated 2010. they only had the 24v one then. The 36v one started in about 2013, so the second one from 2012 is most likely 24v too.
Reactions: tillson
30,778
Yes, both nominal 24 volt series 2 units, though using the 25.9 volt nominal lithium batteries,
The later 2012 model will have the potentially higher output on the Hi power setting, probably 2 times rider input rather than the original 1.3 times, though there was an interim stage of 1.5 times.
I say potentially because the system's motor couldn't match a high rider input with 2 times power.
