I have a folding electric bike and find that the speed of the pedal assist is a bit too fast for the gearing. I have looked at the controller and there is what appears to be an adjusting screw but when it is turned it makes no difference. In view of this I tend to ride using the twist grip so I can regulate my speed better. Will the battery and motor use less power using the twist grip at a these lower speed or is it best to use the pedal assist ( which I presume is set to the optimum)and just change the gearing?
I find that the throttle uses considerably more power and the battery runs down much quicker, if you don't pedal (which is tempting with the throttle)..
On my bike, pedal assist seems much quicker compared to the throttle, even with the fully open, but probably because I'm pedalling on assist all the time..
I also have a folding bike.. my controller has 7 levels of power assist and can be set it very low to conserve power and for safety. I find sometimes if I'm at the highest level I can get caught off guard, the bike just runs away, sometimes at dangerous times :-/
