Pedals seized with mid-drive
Nixtoo
103
47
My bike has been stuck at my holiday home through lock down. I got it out at the weekend to find the pedals stuck. It’s a Marin Stinson with a GSM mid drive conversion. I’m going to try and remove everything today. Is there anything specific I should look for? The motor is fine and turns the Chain with the throttle, just the pedals that won’t budge! Thanks
2,831
Just to clarify, do you mean the pedals won't rotate about their axis on the crank, or the crank won't rotate.
Bikes4two
1,078
462
Havant
37489
Nixtoo
103
47
Sorry I should have been more specific, the crank won’t rotate, the pedals themselves will rotate. Thanks
Nixtoo
103
47
What type of tool would I need to undo this nut? There are 4 little indentations.37517
17,234
you may have to make your own.
Jim @ woosh cuts a steel tube with a hacksaw to make two prongs.
Alternatively, use a pair of thin long nose pliers.
