Pendleton Battery
Jaspa9102
Hi Guys , i brought my wife a pendleton and the battery is flashing the code for a dead cell ? where or does anyone recell on here , the charger goes red when plugging in then flashes red
3,994
You can't go any further forward unless you have a voltmeter. You need to measure the voltage on the battery output terminals and tell us what it is.
Jaspa9102
Hi , i measured it yesterday and it is about 32v , the charger wont go above that
Jaspa9102
Put a new battery in your meter because your result shows that it's run out, then test again and give us the exact reading/
Hi , tried a new battery in meter and plugged in charger and now it’s gone up to 37v and charger is staying on so I’ll leave it and see if it charges ?
I’m confused lol
2,836
It should charge up to somewhere around 42v.
Jaspa9102
Right , it has charged up to 42v , if I press and hold the power button it drops to 20v and goes into sleep mode , plug in charger it wakes up and flashes 5 lights then goes off and then flashes the code for dead cell
I took the battery apart and pulled the plug for the balance wires and measured each one and they go up in 4.1-2v increments, so that tells me that the cells must be good ?
proper confused here , I’m going to put it back on the bike tomorrow and see what happens
8,788
We need to see the actual 10 cell voltage results you saw, 4.1 - 4.2v is quite a bit of difference between individual cell groups and isn't a good sign.
Jaspa9102
I'll measure the individual and give the readings later , will 0.1 of a volt make such a differance ?
8,788
0.1v if balanced isn't great, cells in good nick will be with in 0.02v.
One will need to place a load on it and wire the dvm in temporary to see what occurs with the voltage, if it collapses then the a cell/s are knackered. One can do it with the wheel off the ground use PAS or throttle and gently apply the brake for a load reading see what happens to the V's.
