My 36v 10ah lifepo4 isn't Ping but almost identical and may use same cell's[24 x 5ah pouches] Straight off charger approx 42volt, after a week standing 40.5volt. Bms low volt cut approx 2.9-3.0volts per cell for lifepo4. As there's 12 cell's in series low voltage cutoff takes place at approx 35-36volts.Thank you mutmost![]()
I didn't think Ping would reply so fast, but he has triumphed again![]()
His reply was:
The fully charged voltage fresh off the charger is around 45v. But after a while of the charger is disconnected, the voltage will drop to around 42-43v.
The nominal voltage is around 38.4v = 3.2*12. The nominal working voltage is 36v.
Now that's what i call customer service![]()
