Hi I have an old Powabyke with SLA batteries (yes I know ). The charger blew up a while ago and I bought the cheapest one on eBay but I am not sure it is working properly. The range of the bike is rather poor. It barely manages 6 miles. It is possible the batteries have just worn out.
The bike has 3 x CSB EVH12150 12V 15Ah. The full charge voltage from the batteries is 40.2V and the output from the charger when disconnected is 41.6V. I haven't measured the actual voltage when charging but I suppose I could break into the link somewhere.
According to the datasheet the minimum charging voltage is 14.4V per battery i.e. 43.2V so it seems a bit low.
https://www.avacom.cz/Datasheety/CSB/PBCS-12V015-F2AD.pdf
I also have a Powabyke charger for the Li-ion battery, do you think it would work?
