Powacycle Mode Switch
Del 80
216
7
72
Lincolnshire
On the Powacycle Salisbury, there is a mode switch on the left of the handlebars, presumably this is a three way switch, off, pedal assist and throttle, on mine the off position does not appear to work, e.g. it is always in pedal assist mode, anyone know how to fix this ?.......Del.
muckymits
419
So I have been told none of them ever worked in triple mode, as long as your switch does pedlec and/or throttle its ok. If you want the other mode you turn the key :rolleyes:
30,855
There's been quite a few e-bikes like this, comes of using generic components used on other makes and models at different times.
Del 80
216
7
72
Lincolnshire
Was going to take it apart flecc, but on reflection best left alone, as Muckymits says, you can always turn the power off, using the key.......Del.
