Powacycle Salisbury LPX Mystery Cable
Sophies Dad
9
Been taking a look at the wiring in my 'powacycle salisbury' and come across this plug (marked as 'D') coming from the controller... black and brown wires in a small two way male plug... any ideas what it might be for? :confused:
frank9755
1,228
London
Sorry I don't know the answer to your query but I'll have a think about it and compare with other controllers I've seen.
I just wanted to say what an excellent drawing!
30,857
Often these additional plugs are for optional bike lighting from the main battery. Some series of the old type Panasonic unit had a similar spare, but I can't say specifically on the Powacycle.
Sophies Dad
9
Often these additional plugs are for optional bike lighting from the main battery...
That would be cool as I am looking for a better way to supply my lights... am a bit worried if you are right and they have used a male plug to supply power from and left it exposed where it might short against the frame given a small amount of rain water... will put a test on it with my multimeter later today:rolleyes:
frank9755
1,228
London
There are various things it could be.
Lights is a possibility but I'd have thought it unlikely as not many controllers have them.
It could be a de-restrict option - if you short the two wires it may de-restrict the bike.
Difficult to know I'm afraid, without trying it and seeing what happens, which is not without risk.
As a comparison, this is a diagram for a Wisper controller. The bikes do share many components so I don't know if this might shed any light on things.
30,857
Lighting connections are very common on the cheaper Chinese bike controllers, and Powacycle may have had a different batch at one point. The only other "spare" connector I've known of is when programming is possible, but I very much doubt it would have a programmable controller.
Sophies Dad
9
Thanks for all your input... i appreciate your time... i think i am going to carry on my study and see where the wires go inside the controller, try and figure out what does what.
Will report back when i find out!
Sophies Dad
9
Okay... tested the brown and black wires and it turns out to be a 27v supply seemingly straight off the battery... independent of switches.
So it seems you may be right about the lighting idea...
Now I just need to figure out a good lighting design I can fix to the bike on a permanent basis. I usually arrive home after my 12 mile round trip with 2 of the 3 bars still lit on my battery indicator so it should not put my battery under too much stress.
I think a trip to maplins might be called for. :rolleyes:
30,857
Thanks for the confirmation Sophies Dad. On most of the controllers seen here the lighting connections aren't wired, but they are often there.
frank9755
1,228
London
Good luck with your lighting project.
I've just come across this on the eBikes.ca site, while looking for something else. They are going to start stocking front and rear lights which will work at anything from 16-100v. No other details there yet, and probably won't be for a couple of months, but might be a useful product for those who want a solution without too much work required.
