Powered on once then didn't turn on again
HolyJ001
May 31, 2020
Just brought a Voilamart 1000w 48v conversion kit alongside a Yosepower 1000w 48v battery. Installed everything fine and then powered it on. It came on so we turned the throttle and it worked but the LCD screen was really slow to register the speed and wattage and then when we killed the motor with the brake the wattage went too 100 instead of 0. Turned it off to make sure everything was connected properly which it was then tried to turn it on again and nothing happened.
Anyone else had this problem? If so what was there solution. I really hope its a quick fix because my bike is my only form of transport so I'm pretty stuck until it all gets sorted
8,773
Battery fuse ?
